[mapguide-users] Tooltip on the marker
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Aug 13 03:01:26 EDT 2008
What do you mean you don't fill it out?
When you create a temporary featuresource, it gets an id like
"Session:xxxx-yyyy//temp.FeatureSource".
You must insert that name into the resourceID tag, otherwise it won't show.
Can you display the features if there is no tooltip ?
If yes, keep in mind that you have to REALLY precise to hit the correct
pixel before the tooltip shows on a point.
Regards, Kenneth Skovhede, GEOGRAF A/S
gracecwl skrev:
> Hi Kenneth,
> I no fill out resourceID because i create new 'temporary layer' like in
> sheboygan example.
> I have try with column name but still same problem- no output.
> I cant try with load the layer manually, since that is a new  temporary
> layer.However, i try the tooltip state ment in manual load without any
> problem.
> thanks and regards,
> grace
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I assume you fill out the resourceID somehow.
>> Although it should work with just a string constant, have you tried with
>> a column name?
>> I'm not sure if tooltips work on data with no primary key, have you
>> tried it on data where there is a primary key?
>> If you try to load the layer manually, and open it in Studio or Maestro,
>> with a real data source, does that work then?
>> gracecwl skrev:
>>> Hi all,
>>> I try the method suggested, however, i cant get the desired output.
>>> May i know what happen. attached is my .xml file.
>>> http://www.nabble.com/file/p18937171/parcelmarker.xml parcelmarker.xml
>>> Farah-2 wrote:
>>>> Hi..!
>>>> It is possible to create tooltips for the pushpin markers. All u need to
>>>> do
>>>> is modify your layer xml file.
>>>> You need to add:
>>>> <ToolTip> Property Name</ToolTip>
>>>> In your layer.xml file.
>>>> Regards
>>>> Farah
>>>> -----Original Message-----
>>>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>>>> Sent: Monday, November 06, 2006 8:45 AM
>>>> To: users at mapguide.osgeo.org
>>>> Subject: [mapguide-users] Tooltip on the marker
>>>> hi all,
>>>> is that possible to create tooltip for the markers(push pin) just like
>>>> when
>>>> we add a tooltip features on a layer using mapguide studio?
>>>> I am looking forward for the reply and thank you for the guidance..
>>>> Regards,
>>>> Kencana
>>>> View this message in context:
>>>> http://www.nabble.com/Tooltip-on-the-marker-tf2580163.html#a7192696
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/b895f660/attachment.html
