[mapguide-users] Tooltip on the marker
gracecwl gracecwl at sains.com.my
Wed Aug 13 20:48:20 EDT 2008
Hi Kenneth,
I trace down the code, i realise that the value of ResourceID is assigned
somewhere in the code. Therefore, i have no problem display the temporary
layer.
But so far, do you find out any problem with my .xml code which cause the
tooltip cant be showed?FYI, i more my cursor almost whole piece of my
'marker' but stil nothing show.
thanks for your helpfulness
regards,
grace
Kenneth Skovhede, GEOGRAF A/S wrote:
> What do you mean you don't fill it out?
> When you create a temporary featuresource, it gets an id like
> "Session:xxxx-yyyy//temp.FeatureSource".
> You must insert that name into the resourceID tag, otherwise it won't
> show.
> Can you display the features if there is no tooltip ?
> If yes, keep in mind that you have to REALLY precise to hit the correct
> pixel before the tooltip shows on a point.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> gracecwl skrev:
>> Hi Kenneth,
>> I no fill out resourceID because i create new 'temporary layer' like in
>> sheboygan example.
>> I have try with column name but still same problem- no output.
>> I cant try with load the layer manually, since that is a new  temporary
>> layer.However, i try the tooltip state ment in manual load without any
>> problem.
>> thanks and regards,
>> grace
>>> I assume you fill out the resourceID somehow.
>>> Although it should work with just a string constant, have you tried with
>>> a column name?
>>> I'm not sure if tooltips work on data with no primary key, have you
>>> tried it on data where there is a primary key?
>>> If you try to load the layer manually, and open it in Studio or Maestro,
>>> with a real data source, does that work then?
>>> gracecwl skrev:
>>>> Hi all,
>>>> I try the method suggested, however, i cant get the desired output.
>>>> May i know what happen. attached is my .xml file.
>>>> http://www.nabble.com/file/p18937171/parcelmarker.xml parcelmarker.xml
>>>> Farah-2 wrote:
>>>>> Hi..!
>>>>> It is possible to create tooltips for the pushpin markers. All u need
>>>>> to
>>>>> do
>>>>> is modify your layer xml file.
>>>>> You need to add:
>>>>> <ToolTip> Property Name</ToolTip>
>>>>> In your layer.xml file.
>>>>> Regards
>>>>> Farah
>>>>> -----Original Message-----
>>>>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>>>>> Sent: Monday, November 06, 2006 8:45 AM
>>>>> To: users at mapguide.osgeo.org
>>>>> Subject: [mapguide-users] Tooltip on the marker
>>>>> hi all,
>>>>> is that possible to create tooltip for the markers(push pin) just like
>>>>> when
>>>>> we add a tooltip features on a layer using mapguide studio?
>>>>> I am looking forward for the reply and thank you for the guidance..
>>>>> Regards,
>>>>> Kencana
>>>>> View this message in context:
>>>>> http://www.nabble.com/Tooltip-on-the-marker-tf2580163.html#a7192696
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Tooltip-on-the-marker-tp7192696p18973959.html
