[mapguide-users] Map or Layer Preview don't show the Geometry
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Wed Aug 13 06:25:08 EDT 2008
Alex,
Yes, it is known.
Here is the sql 'knowledge' you need to transform your table. Just plug
in the new SRID, in this case I transform to SRID = 8307. Also
sdo_geometry column in this case is 'geometry'. Your 'time' issue I am
not sure of but for me a transform of 200M records takes about 15
seconds.
update YOUR_TABLE_NAME_HERE c set c.GEOMETRY = (select
SDO_CS.TRANSFORM(c.GEOMETRY, m.diminfo, 8307) FROM
user_sdo_geom_metadata m WHERE m.table_name = 'YOUR_TABLE_NAME_HERE');
-- After completion make sure your user_sdo_geom_metadata entry for the
table is correct.
I wish I had a real solution for you. The way it was handed down to me
is that MGOS does not like EPSG codes so it abends the methods. (it
certainly does this well)
IF the MGOS dev folks have addressed the issue their decision on
resolution is unknown to me.
r,
dennis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Alexander
Fischer
Sent: Wednesday, August 13, 2008 4:53 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Map or Layer Preview don't show the
Geometry
So, is this error known that some CoordinateSystems are not working with
MGOS? Is there anywhere a list of these CoordinateSystems? I still hope
that I made a mistake because I have neither the time nor the knowledge
to transform the whole database into another WKT.
Kind regards,
Alex
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/88fde865/attachment.html
