[mapguide-users] Map or Layer Preview don't show the Geometry
Zac Spitzer zac.spitzer at gmail.com
Wed Aug 13 06:26:52 EDT 2008
did you try to override the feature source co-ordinates system?
On Wed, Aug 13, 2008 at 8:25 PM, Jonio, Dennis (Aviation)
<DJonio at miami-airport.com> wrote:
> Alex,
> Yes, it is known.
> Here is the sql 'knowledge' you need to transform your table. Just plug in
> the new SRID, in this case I transform to SRID = 8307. Also sdo_geometry
> column in this case is 'geometry'. Your 'time' issue I am not sure of but
> for me a transform of 200M records takes about 15 seconds.
> update YOUR_TABLE_NAME_HERE c set c.GEOMETRY = (select
> SDO_CS.TRANSFORM(c.GEOMETRY, m.diminfo, 8307) FROM user_sdo_geom_metadata m
> WHERE m.table_name = 'YOUR_TABLE_NAME_HERE');
> -- After completion make sure your user_sdo_geom_metadata entry for the
> table is correct.
> I wish I had a real solution for you. The way it was handed down to me is
> that MGOS does not like EPSG codes so it abends the methods. (it certainly
> does this well)
> IF the MGOS dev folks have addressed the issue their decision on resolution
> is unknown to me.
> r,
> dennis
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Alexander
> Fischer
> Sent: Wednesday, August 13, 2008 4:53 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Map or Layer Preview don't show the Geometry
> So, is this error known that some CoordinateSystems are not working with
> MGOS? Is there anywhere a list of these CoordinateSystems? I still hope that
> I made a mistake because I have neither the time nor the knowledge to
> transform the whole database into another WKT.
> Kind regards,
> Alex
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
