[mapguide-users] MGOS 2.0.1 Crash Issues
nclayton nclayton at gmail.com
Thu Aug 14 11:42:19 EDT 2008
That's the sticky part, because with it being available to the public (which
I'm in the process of switching out pages so that the general public no
longer goes to the mgos pages) it had to have the rasters in place. If I'm
the only one hitting the pages, with or without rasters, it works
flawlessly. It's only after it's been used by the public for some time (but
not all that long...15 - 30 minutes) and it crashes.
zspitzer wrote:
> how do they perform if you remove the rasters ?
> On Fri, Aug 15, 2008 at 1:23 AM, nclayton <nclayton at gmail.com> wrote:
>> The old server is no longer in use so I can't give specifics on its
>> specs.
>> The new box is:
>> Windows 2003 Server Standard Edition SP2
>> 2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
>> IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
>> Application Pool)
>> 4GB RAM
>> Attached is my serverconfig.ini file. I didn't make many changes to it,
>> other than changing the repository paths. I honestly am not 100% sure of
>> what effects most of the settings have on the system.
>> Here's a list of the currently available urls in case someone might can
>> see
>> something I've done in the maps that could cause some of my problems:
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
>> They all use the same layer styles...I just copy the layers to a new
>> county
>> folder, change where the file points to and add it to a new county map.
>> Each
>> county has a set of ECW raster files.
>> zspitzer wrote:
>>> can you describe the specs of the two machines ?
>>> had you tweaked the serverconfig.ini for the size of the machine?
>>> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>>>> yeah, I had that in place. It's odd that some of these errors only
>>>> started
>>>> happening on this new box which has a lot more horsepower than the
>>>> previous
>>>> one.
>>>> i'm going to keep mgos installed and try to do some testing to try to
>>>> figure
>>>> out what exactly is causing things to die on me.
>>>> Rock Beans wrote:
>>>>> That is to bad. It might have been something easy to fix. Was you
>>>>> installation patched to fix the Firefox 3 crash bug?
>>>>> The Rock
>>>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>>>> maps
>>>>>> back
>>>>>> to mapguide 6.3
>>>>>> hopefully things will smooth out more in future releases.
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>> http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18984203.html
