[mapguide-users] MGOS 2.0.1 Crash Issues
Andy Morsell amorsell at spatialgis.com
Thu Aug 14 11:44:44 EDT 2008
I have similar crashing problems with 2.0.1 and also suspect raster issues,
although there are no clues in the error or event logs about this.  The
reason I suspect raster issues is that when things start to go wonky, maps
with no raster work for a little while maps with raster fail to render.
Eventually, mgserver faults and locks up.
The one common denominator for those with instability issues seems to be
running MGOS with IIS / .NET.  Is that the case for all with these problems?
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, August 14, 2008 8:37 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 2.0.1 Crash Issues
how do they perform if you remove the rasters ?
On Fri, Aug 15, 2008 at 1:23 AM, nclayton <nclayton at gmail.com> wrote:
> The old server is no longer in use so I can't give specifics on its specs.
> The new box is:
> Windows 2003 Server Standard Edition SP2
> 2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
> IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
> Application Pool)
> 4GB RAM
> Attached is my serverconfig.ini file. I didn't make many changes to it,
> other than changing the repository paths. I honestly am not 100% sure of
> what effects most of the settings have on the system.
> Here's a list of the currently available urls in case someone might can
see
> something I've done in the maps that could cause some of my problems:
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
> They all use the same layer styles...I just copy the layers to a new
county
> folder, change where the file points to and add it to a new county map.
Each
> county has a set of ECW raster files.
> zspitzer wrote:
>> can you describe the specs of the two machines ?
>> had you tweaked the serverconfig.ini for the size of the machine?
>> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>>> yeah, I had that in place. It's odd that some of these errors only
>>> started
>>> happening on this new box which has a lot more horsepower than the
>>> previous
>>> one.
>>> i'm going to keep mgos installed and try to do some testing to try to
>>> figure
>>> out what exactly is causing things to die on me.
>>> Rock Beans wrote:
>>>> That is to bad. It might have been something easy to fix. Was you
>>>> installation patched to fix the Firefox 3 crash bug?
>>>> The Rock
>>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>>> maps
>>>>> back
>>>>> to mapguide 6.3
>>>>> hopefully things will smooth out more in future releases.
>>>>> View this message in context:
>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
Zac Spitzer -
+61 405 847 168
