[mapguide-users] MGOS 2.0.1 Crash Issues
nclayton nclayton at gmail.com
Thu Aug 14 11:51:11 EDT 2008
Something else I forgot to mention, thanks for bringing that up Andy!
I'm running IIS / PHP and using MySQL for the backend (using odbc
connections instead of mysql connections)
Andy Morsell wrote:
> I have similar crashing problems with 2.0.1 and also suspect raster
> issues,
> although there are no clues in the error or event logs about this.  The
> reason I suspect raster issues is that when things start to go wonky, maps
> with no raster work for a little while maps with raster fail to render.
> Eventually, mgserver faults and locks up.
> The one common denominator for those with instability issues seems to be
> running MGOS with IIS / .NET.  Is that the case for all with these
> problems?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Thursday, August 14, 2008 8:37 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGOS 2.0.1 Crash Issues
> how do they perform if you remove the rasters ?
> On Fri, Aug 15, 2008 at 1:23 AM, nclayton <nclayton at gmail.com> wrote:
>> The old server is no longer in use so I can't give specifics on its
>> specs.
>> The new box is:
>> Windows 2003 Server Standard Edition SP2
>> 2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
>> IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
>> Application Pool)
>> 4GB RAM
>> Attached is my serverconfig.ini file. I didn't make many changes to it,
>> other than changing the repository paths. I honestly am not 100% sure of
>> what effects most of the settings have on the system.
>> Here's a list of the currently available urls in case someone might can
> see
>> something I've done in the maps that could cause some of my problems:
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
>> They all use the same layer styles...I just copy the layers to a new
> county
>> folder, change where the file points to and add it to a new county map.
> Each
>> county has a set of ECW raster files.
>> zspitzer wrote:
>>> can you describe the specs of the two machines ?
>>> had you tweaked the serverconfig.ini for the size of the machine?
>>> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>>>> yeah, I had that in place. It's odd that some of these errors only
>>>> started
>>>> happening on this new box which has a lot more horsepower than the
>>>> previous
>>>> one.
>>>> i'm going to keep mgos installed and try to do some testing to try to
>>>> figure
>>>> out what exactly is causing things to die on me.
>>>> Rock Beans wrote:
>>>>> That is to bad. It might have been something easy to fix. Was you
>>>>> installation patched to fix the Firefox 3 crash bug?
>>>>> The Rock
>>>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>>>> maps
>>>>>> back
>>>>>> to mapguide 6.3
>>>>>> hopefully things will smooth out more in future releases.
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>> http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18984358.html
