[mapguide-users] login to mapguide server 2.0
Rock Beans rockbeans at gmail.com
Tue Aug 19 16:12:18 EDT 2008
Thanks for the link! Yes, the Registry entry has been a main issue
with installs as far as the php.ini file. Very confusing issue at
times I have had to point IIS at the php-cgi.exe as the only work
around.
The Rock
On Tue, Aug 19, 2008 at 10:54 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> here is the bug  http://trac.osgeo.org/mapguide/ticket/454
> On Tue, Aug 19, 2008 at 11:21 PM, Rock Beans <rockbeans at gmail.com> wrote:
>> Most likely this is caused by the MapAdmin PHP not being able to write to
>> the temp directory. You can Google PHPInfo() and make a nice test page that
>> will display your system settings. Within the PHP.ini you can change the
>> SAVE_PATH but make sure it's writable to IUSER. I sometimes just add
>> "Everyone" to save time. If that is not it use PHPInfo to find what config
>> ini PHP is using. It should be using the one located in the MapGuideOS Web
>> PHP folder but if not that would also casue some issues.
>> The Rock
>> On Tue, Aug 19, 2008 at 3:00 AM, Grace Chai <gracecwl at sains.com.my> wrote:
>>> Hi,
>>> Anyone has idea why i unable to login into mapguide server 2.0 using the
>>> default user name 'Administrator' and password "admin". Is that because the
>>> login info wrong or because installation problem
>>> thanks and regards,
>>> Grace
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
