[mapguide-users] login to mapguide server 2.0
Zac Spitzer
zac.spitzer at gmail.com
Tue Aug 19 11:54:32 EDT 2008
here is the bug http://trac.osgeo.org/mapguide/ticket/454
On Tue, Aug 19, 2008 at 11:21 PM, Rock Beans <rockbeans at gmail.com> wrote:
> Most likely this is caused by the MapAdmin PHP not being able to write to
> the temp directory. You can Google PHPInfo() and make a nice test page that
> will display your system settings. Within the PHP.ini you can change the
> SAVE_PATH but make sure it's writable to IUSER. I sometimes just add
> "Everyone" to save time. If that is not it use PHPInfo to find what config
> ini PHP is using. It should be using the one located in the MapGuideOS Web
> PHP folder but if not that would also casue some issues.
> The Rock
> On Tue, Aug 19, 2008 at 3:00 AM, Grace Chai <gracecwl at sains.com.my> wrote:
>> Hi,
>> Anyone has idea why i unable to login into mapguide server 2.0 using the
>> default user name 'Administrator' and password "admin". Is that because the
>> login info wrong or because installation problem
>> thanks and regards,
>> Grace
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
