[mapguide-users] Fusion - how to set min zoom level?
Mike Adair madair at dmsolutions.ca
Fri Aug 22 14:00:54 EDT 2008
I just fixed a bug that sounds similar to that:
http://trac.osgeo.org/fusion/ticket/108.  The initial view was
overriding the max extent returned by MapGuide.  This is on the trunk
version (soon to be in a 1.1 version)
Mike
Andrew DeMerchant wrote:
> I don't have defined scales for my map. I have an initial view
> location - In my case, AJAX most certainly does _not_ act like Fusion.
> In AJAX, my map loads at 1:147716.....I can use the zoom slider to
> zoom out to 1:4947533 (plenty far!). In Fusion, it loads at 1:146319,
> but like I say, the zoom slider is all the way at the bottom...I can't
> zoom out anymore. I can't even type in a new scale manually...
> Andrew
> Maksim Sestic wrote:
>> Andrew,
>> AJAX acts in the same way if you have fixed set of scales defined for a map.
>> Regards,
>> Maksim Sestic
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>> DeMerchant
>> Sent: Friday, August 22, 2008 17:57
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Fusion - how to set min zoom level?
>> Thanks - but I know how to set my initial view. I just want to be able to
>> zoom out more, beyond that initial view. Right now, in Fusion (not in AJAX
>> or DWF) I can't zoom out past my initial view.
>> Andrew
>> Rodolfo Moreno wrote:
>>> I suposse that you are using studio 2009, well first you must define
>>> an extent greater that your layers.
>>> These values are accordign to your preference. It depends that how
>>> many you want to zoom out.
>>> Next you have that setting the map widget located in your flexible layout.
>>> Choose the radio button option "use custom view" and place the scale
>>> and the center coordinates of you preference. These values will
>>> determine the initial zoom.
>>> Regards
>>>> In my Fusion maps, I've just noticed that I can't zoom out beyond my
>>>> initial map view. The zoom slider starts out at the bottom - this
>>>> happens on all of my Fusion layouts. How do I set a different zoom
>>>> out max limit (using Studio / Maestro)?
>>>> Andrew
>>>> 	*Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Rodolfo Moreno
>>> CivilEng
>> __________ Information from ESET NOD32 Antivirus, version of virus signature
>> database 2888 (20080220) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
>> http://www.eset.com
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
