[mapguide-users] Mapguide Enterprise 2009 and Oracle View
Francesco Visentin francesco.visentin at provincia.padova.it
Tue Aug 26 10:06:03 EDT 2008
I found a way to make the "view data" displayed in Enterprise 2009.
Here my solution, with Autodesk Commercial FDO for Oracle with Oracle 10g
I have a table (TABLE_1) with a spatial column (GEOMETRY), and a slave table
(TABLE_2) with some other related fields.
1) Create a spatial index for TABLE_1, and register TABLE_1 into
MDSYS.SDO_GEOM_METADATA_TABLE
2) Create the view between TABLE_1 and TABLE_2. (in this case: VIEW_1)
3) Manually insert a new row into MDSYS.SDO_GEOM_METADATA_TABLE by copying
the values of TABLE_1 row.
You only need to modify  the SDO_TABLE_NAME field value, by inserting the
name of the view (VIEW_1 in this case)
4) Into MapguideStudio, refresh the Oracle Connection (deleting and recreate
the connection is the best way :) )
5) Create the new layer from VIEW_1
This works for me...
Regards
V.
View this message in context: http://www.nabble.com/Mapguide-Enterprise-2009-and-Oracle-View-tp19139820p19162779.html
