[mapguide-users] Feature Joins - How?
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Mon Aug 25 08:55:32 EDT 2008
Trying to understand feature joins so I tried some tests and failed
miserably... can anyone expand on the logic below:
 1) I created a new featuresource and layer (SDF data), turned the FeatId on
as the tooltip and previewed the data, noted down a FeatId that I could
readily identify (e.g. 123)
 2) I created an Access DB with a new table and a column (Numeric, Long)
called ID_NumLong and made it a primary key, then added one value to the
table as noted above (e.g. 123)
 3) I added an ODBC system DSN to the MDB and in MapGuide a new ODBC feature
source connection.
 4) I edited my original layer, linked the new ODBC featuresource as a join
and selected FeatId->ID_NumLong as an Inner join
 5) Previewed the layer expecting to see only the linked feature displayed
... but the complete dataset displayed as before.  Not happy.
View this message in context: http://n2.nabble.com/Feature-Joins---How--tp781352p781352.html
