[mapguide-users] Is there a file size limit?
Martin Morrison martin.morrison at edsi.com
Tue Aug 26 16:55:46 EDT 2008
Are you using a bunch of small segments for lines or a long polyline
with multiple vertexes?  Can you generalize the data for when you are
zoomed out and then switch layers to one with more detail as you zoom
in?
Martin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
Sent: Tuesday, August 26, 2008 4:48 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Is there a file size limit?
Yes we turned all other layers off and even tried removing them
completely.
This is a line layer and double line layer for rivers and polygon layer
for
lakes. So it is a mix of several layers. Yes there is labelling but we
turned it off to try to speed things up.  We just increased the cache
size
in the ini file and this seems to have helped with speed but it is still
very slow when we select a stream to get its properties.  I don't know
which
line style is being used, I will have to get back to you on that
question.
thanks
brad
Traian Stanev wrote:
> There is no size limit. To make sure this layer is to blame, did you
turn
> off all other layers when viewing the map? Also, is this a line layer
or a
> polygons layer. What line style or polygon style is it using to
render? Is
> there labeling?
> Traian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> Sent: Tuesday, August 26, 2008 4:15 PM
>> Subject: [mapguide-users] Is there a file size limit?
>> After upgrading from MGE2008 to MGE2009 we have noticed a severe
>> decline in
>> map rendering speed for our hydrology layer for British Columbia.
The
>> sdf
>> file is about 800megs and is in the map repository. Is there a file
>> size
>> limit?  We have tried to optimize the server to improve speeds with
no
>> success. Any suggestions welcomed.
>> View this message in context: http://www.nabble.com/Is-there-a-file-
>> size-limit--tp19169522p19169522.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/Is-there-a-file-size-limit--tp19169522p19170081.ht
ml
