[mapguide-users] upload a new template for flexible layout
Rodolfo Moreno rmoreno at voxiva.com
Fri Aug 29 12:02:38 EDT 2008
Thans a lot to all, Finally I could  generate my template in mgstudio.
Chris was in the rigth. I create a new template Info in the location
suggested and it's only necessary to refresh the template list in mgstudio.
Best regards
Chris Claydon wrote:
> You shouldn't need to re-start the server, but you may need to re-start
> Studio, or a least right-click in the template list and pick "Refresh".
> In order for the template to show up in Studio, you need to create a
> template info XML file for it in the following location:
> <MgInstallLocation>\WebServerExtensions\www\fusion\templates\mapguide
> This folder should already contain similar XML files for the other
> templates (e.g. aqua.xml, limegold.xml, slate.xml etc.)
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Friday, August 22, 2008 4:56 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] upload a new template for flexible layout
> Maybe you need to restart the MapGuide Server for the new template to be
> picked up. Does your template have the xml file that describes it?
> - Jackie
> Rodolfo Moreno wrote:
>> thanks Jackie,
>> I have already copy my template to the template directory, but I can't
>> see
>> my template in MG STUDIO.
>> Best Regards
>> Jackie Ng wrote:
>>> MapGuide does not expose template uploading services. You will have to
>>> manually copy the template to the fusion template directory via
>>> ftp/shared network folders/etc.
>>> - Jackie
>>>> Hi all, I have created a new flexible layout but and now I want to
>>>> upload into MAPGUIDE SERVER, in order to appear how another layout
>>>> template in STUDIO / MAESTRO. How could it be done?
>>>> Thanks in advance
> http://n2.nabble.com/upload-a-new-template-for-flexible-layout-tp759827p777269.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/upload-a-new-template-for-flexible-layout-tp759827p792506.html
