[mapguide-users] Execute a script with mapgudie studio 2.0
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Dec 12 07:46:16 EST 2008
The "Command Name" is not the name of a file, it's a logical name of the
command, used to identify it in Studio.
In the "Additional Parameters" area, you enter a javascript.
If you enter the name of a file, it won't load, because a filename is
not a javascript.
If your script is in an aspx page, you can try the "invoke url" option
instead.
Regards, Kenneth Skovhede, GEOGRAF A/S
ziburudebian at free.fr skrev:
> I means that in my layout file in mapguide studio, i parameter the new command
> (tools and menus) : i create a new custom command : 'Execute a script'. In the
> aera 'Adding Parameters' Mapguide studio Help indicate that you must edit the
> name of your script : so i take myfile.aspx.
> But when i run, nothing occurs !
> Thanks
> Selon Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
>> What do you mean by "edit the nameo f my aspx file"? Could you be more
>> specific?
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of euskalmap
>> Sent: Friday, December 12, 2008 10:32 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Execute a script with mapgudie studio 2.0
>> hi,
>> when i try to execute a script with a custom command in mapguide studio
>> nothing occurs;
>> if i edit an instrction like alert("hello") , it is run but if a edit
>> the
>> name of my aspx file myfiles.aspx, for example) , nothing occurs
>> have you an idea?
>> thanks
>> euskalmap
>> config.
>> mapguide ose 2.2
>> windows 2003 server sp2
>> View this message in context:
>> http://www.nabble.com/Execute-a-script-with-mapgudie-studio-2.0-tp209715
>> 93p20971593.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081212/a0ed397f/attachment.html
