[mapguide-users] Execute a script with mapgudie studio 2.0
euskalmap ziburudebian at free.fr
Fri Dec 12 08:16:46 EST 2008
Ok, thanks very match, i have understand
regards
Kenneth Skovhede, GEOGRAF A/S wrote:
> The "Command Name" is not the name of a file, it's a logical name of the
> command, used to identify it in Studio.
> In the "Additional Parameters" area, you enter a javascript.
> If you enter the name of a file, it won't load, because a filename is
> not a javascript.
> If your script is in an aspx page, you can try the "invoke url" option
> instead.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> ziburudebian at free.fr skrev:
>> I means that in my layout file in mapguide studio, i parameter the new
>> command
>> (tools and menus) : i create a new custom command : 'Execute a script'.
>> In the
>> aera 'Adding Parameters' Mapguide studio Help indicate that you must edit
>> the
>> name of your script : so i take myfile.aspx.
>> But when i run, nothing occurs !
>> Thanks
>> Selon Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
>>> What do you mean by "edit the nameo f my aspx file"? Could you be more
>>> specific?
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of euskalmap
>>> Sent: Friday, December 12, 2008 10:32 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] Execute a script with mapgudie studio 2.0
>>> hi,
>>> when i try to execute a script with a custom command in mapguide studio
>>> nothing occurs;
>>> if i edit an instrction like alert("hello") , it is run but if a edit
>>> the
>>> name of my aspx file myfiles.aspx, for example) , nothing occurs
>>> have you an idea?
>>> thanks
>>> euskalmap
>>> config.
>>> mapguide ose 2.2
>>> windows 2003 server sp2
>>> View this message in context:
>>> http://www.nabble.com/Execute-a-script-with-mapgudie-studio-2.0-tp209715
>>> 93p20971593.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
euskalmap,
My configuration
Mapguide OSE 2.2
Autodesk Mapguide Studio 2009
Windows XP PRO SP2
I.I.S 6.0
View this message in context: http://www.nabble.com/Execute-a-script-with-mapgudie-studio-2.0-tp20971593p20975455.html
