[mapguide-users] SDF convertion question
Nandorov nandorov at gmail.com
Fri Dec 19 15:45:26 EST 2008
my bad. Thanks, Jackie.
but now i get errors while trying to see the data. even for shapes and
sdf's. i might be missing something or my fdo toolbox is not correctly
installed.
thanks
Jackie C. Ng wrote:
> Try wrapping your connection string property in double quotes.
> - Jackie
> Moog wrote:
>> Hi Jackie,
>> i download FDO Toolbox, but i can't connect to my .txt file.
>> I've configured the odbc connection, but when i try to make a connection
>> with the driver it fails.
>> my original connection string was
>> Driver={Microsoft Text Driver (*.txt;
>> *.csv)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
>> but because of comma delimiter i got to change it for
>> (*.txt)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
>> but dbq and extensions are invalid connection properties for FDO toolbox.
>> So i just leave the driver and i get this message
>> http://www.nabble.com/file/p21080382/error.jpg
>> Thanks
>> Jackie C. Ng wrote:
>>> You could try using FDO Toolbox (http://fdotoolbox.googlecode.com)
>>> connecting
>>> to the text file via the ODBC Provider (see examples here:
>>> http://www.connectionstrings.com/textfile) and bulk copy it to a new
>>> SDF.
>>> I
>>> haven't actually tried this approach myself, so your mileage may vary.
>>> - Jackie
>>> Moog wrote:
>>>> Hi,
>>>> I wonder if there's a way to create sdf3 files from a text file (SDF
>>>> loader
>>>> from mapguide 6.5 allows to create sdf files from text reading
>>>> coordinates
>>>> with a delimiter).
>>>> Or ¿can i use sdf loader from 6.5 and then use map to export this sdf2
>>>> into
>>>> a sdf3?
>>>> thanks
>>>> View this message in context:
>>>> http://www.nabble.com/SDF-convertion-question-tp21054445p21054445.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/SDF-convertion-question-tp1668183p1670662.html
>>> http://themapguyde.blogspot.com
>>> http://www.linkedin.com/in/jackieng
>> http://www.nabble.com/SDF-convertion-question-tp21054445p21080382.html
> http://n2.nabble.com/SDF-convertion-question-tp1668183p1675217.html
View this message in context: http://www.nabble.com/SDF-convertion-question-tp21054445p21098103.html
