[mapguide-users] SDF convertion question
Jackie C. Ng jumpinjackie at gmail.com
Fri Dec 19 21:44:26 EST 2008
What kind of errors?
- Jackie
Nandorov wrote:
> my bad. Thanks, Jackie.
> but now i get errors while trying to see the data. even for shapes and
> sdf's. i might be missing something or my fdo toolbox is not correctly
> installed.
> thanks
> Jackie C. Ng wrote:
>> Try wrapping your connection string property in double quotes.
>> - Jackie
>> Moog wrote:
>>> Hi Jackie,
>>> i download FDO Toolbox, but i can't connect to my .txt file.
>>> I've configured the odbc connection, but when i try to make a connection
>>> with the driver it fails.
>>> my original connection string was
>>> Driver={Microsoft Text Driver (*.txt;
>>> *.csv)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
>>> but because of comma delimiter i got to change it for
>>> (*.txt)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
>>> but dbq and extensions are invalid connection properties for FDO
>>> toolbox.
>>> So i just leave the driver and i get this message
>>> http://www.nabble.com/file/p21080382/error.jpg
>>> Thanks
>>> Jackie C. Ng wrote:
>>>> You could try using FDO Toolbox (http://fdotoolbox.googlecode.com)
>>>> connecting
>>>> to the text file via the ODBC Provider (see examples here:
>>>> http://www.connectionstrings.com/textfile) and bulk copy it to a new
>>>> SDF.
>>>> I
>>>> haven't actually tried this approach myself, so your mileage may vary.
>>>> - Jackie
>>>> Moog wrote:
>>>>> Hi,
>>>>> I wonder if there's a way to create sdf3 files from a text file (SDF
>>>>> loader
>>>>> from mapguide 6.5 allows to create sdf files from text reading
>>>>> coordinates
>>>>> with a delimiter).
>>>>> Or ¿can i use sdf loader from 6.5 and then use map to export this sdf2
>>>>> into
>>>>> a sdf3?
>>>>> thanks
>>>>> View this message in context:
>>>>> http://www.nabble.com/SDF-convertion-question-tp21054445p21054445.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> http://n2.nabble.com/SDF-convertion-question-tp1668183p1670662.html
>>>> http://themapguyde.blogspot.com
>>>> http://www.linkedin.com/in/jackieng
>>> http://www.nabble.com/SDF-convertion-question-tp21054445p21080382.html
>> http://n2.nabble.com/SDF-convertion-question-tp1668183p1675217.html
View this message in context: http://www.nabble.com/SDF-convertion-question-tp21054445p21101353.html
