[mapguide-users] Connection Problem-ORACLE ODBC Driver(configure odbc connection)
Dave Wilson dave.wilson at autodesk.com
Fri Feb 29 16:19:10 EST 2008
The connection string option does not work. A defect internal to Autodesk has already been logged regarding this. As well when using the instant client your Driver name must change to reflect the instant client you are using "Oracle in instantclient10_2" would be the correct name, however even with that change it still doesn't work. Resolution of the TNSNAMES is not likely the issue based on testing we have done.
The only option that works is to create a DSN wherever your server is installed.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rahul
Sent: Friday, February 29, 2008 4:14 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Connection Problem-ORACLE ODBC Driver(configure odbc connection)
Hi All,
             I am using MGOS 1.2 and Map Guide Studio2008, I am trying to connect to Oracle Database 10.1.0 and i installed Oracle instant client-10.2.0.2 on my machine i.e. MapGuide Server, I also succesully installed oracle odbc driver-win32 10.2.0.3 in order to configure ODBC connection using Oracle(Oracle Driver) in the MapGuide Studio.
I also set the PATH variable to oracle instant client directory as well as also defined ORACLE_HOME and TNS_ADMIN as system variable.
I tried the connection string in th studio as follows -
Driver={Oracle ODBC Driver};Dbq=Database Name;Uid=xxx;Pwd=yyyy;
I also tried to use the another connection setting if it unable to get the values from tnsnames.ora hence i tried
Driver={Oracle ODBC Driver};Dbq=10.X.X.X:1521/abcd;Uid=xxx;Pwd=yyyy;
but i unable to connect to oracle and getting the FDO Error-An Exception Occured in FDO component.RDBMS:No Current open Database but the same database i can connect using the Fdo2Fdo Tools,Any kind of help will be really helpfull for me.
Thks
Max !!
Never miss a thing. Make Yahoo your homepage.<http://us.rd.yahoo.com/evt=51438/*http:/www.yahoo.com/r/hs>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080229/184757de/attachment.html
