[mapguide-users] FW: Problems while labeling polylines
Traian Stanev traian.stanev at autodesk.com
Wed Jan 2 10:15:43 EST 2008
No, I was looking at the latest code, and stuff was moved around, so this is not the section of code I was looking at. Your attachment didn't seem to make it through, so email it to me directly and I can take a look.
About the stitching -- it will try all 4 cases (start-start, start-end, end-start, end-end when attempting to join lines).
Manhattan distance is simply the tolerance metric (see http://en.wikipedia.org/wiki/Taxicab_geometry).
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
> Sent: Wednesday, January 02, 2008 5:25 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] FW: Problems while labeling polylines
> There's MgStylizationUtil::ParseColor(CREFSTRING colorstr, RS_Color&
> rscol)
> sitting at the line 99 of StylizationUtil.cpp (MGOS 1.2.0), is this the
> right one? Please find attached roads LayerDefinition XML if there's a
> chance you can tell from it's contents what prevents proper stitching
> (I'm
> using this layer as a dynamic one, should make no difference). Geometry
> stored in Road feature class is pure LineStrings.
> When you say "fixed 2 pixel Manhattan distance between line endpoints",
> does
> this mean endpoints only (excluding startpoints)? My LineStrings are
> not
> explicitly directed - at least not in any specific order.
> Regards,
> Maksim Sestic
> Traian Stanev wrote:
> > The stitching part is independent of the composite line styles. The
> > specific data source should not have an effect. The custom projection
> > should not matter either.
> > As far as the logic for composite line styles, it is located at line
> 99 of
> > StylizationUtil.cpp. The code has to enter the if condition in order
> for
> > it to work (the comments there explain a bit of what's going on). If
> you
> > look at the logic there and compare to your XML LayerDefinition, you
> may
> > be able to tell why your line style definition does not conform to
> what
> > the code expects.
> > The stitching code is not very smart, it uses a fixed 2 pixel
> Manhattan
> > distance between line endpoints as the limit (it does all the math in
> > pixel space, but in double precision). The relevant code is in
> > LabelRendererBase.cpp, function CloseEnough().
> > Traian
> http://www.nabble.com/file/p14576156/TEST.LayerDefinition.xml
> View this message in context: http://www.nabble.com/FW%3A-Problems-
> while-labeling-polylines-tp14525210s16610p14576156.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
