[mapguide-users] Issue in Draw Polygon
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Mon Jan 14 07:02:58 EST 2008
Javed,
What are you doing with pPgon?
Creating a polygon does just that. You have to add it to the feature
source.
An obvious question ...
	a) Do the points actually make a polygon?
dennis
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JavedPune
Sent: Sunday, January 13, 2008 3:26 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Issue in Draw Polygon
Hey,
I am fairly new to the group. This is my first post. I have a issue with
"Draw polygon".
I am using MapGuide 1.2 when I try to add a polygon by using following
syntax it does not draw. My outer line is defined for polygon and innear
line is not required I try to add "null" in .NET language it does not
draw a
polygon for me.
Dim pPgon As MgPolygon = geometryFactory.CreatePolygon(OLinRin,
inLnRing)
Any help in this matter is appriciated.
Regards
Javed
View this message in context:
http://www.nabble.com/Issue-in-Draw-Polygon-tp14790629s16610p14790629.ht
ml
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
E-mails are automatically scanned for viruses using McAfee.
