[mapguide-users] Issue with Google Maps Mashup with Mapguide
Andy Morsell amorsell at spatialgis.com
Fri Jan 18 13:04:58 EST 2008
It sounds like your MuniMarkers.php page is not returning valid XML.  That
is the page that would contain all of the functionality and use the MGOS API
to request your point data from your feature source and return an XML
document that meets the requirements of the Google Maps marker XML schema.
You should be able to trouble-shoot problems with this page just by trying
to open it in a browser since it does not look like you are doing dynamic
fetches of data based on the bounding box of the Google Map.
Here is a good link that has some information on the XML requirements:
http://econym.googlepages.com/basic3.htm
<markers>
  <marker lat="43.65654" lng="-79.90138" html="Some stuff to display in
the<br>First Info Window" label="Marker One" />
  <marker lat="43.91892" lng="-78.89231" html="Some stuff to display in
the<br>Second Info Window" label="Marker Two" />
  <marker lat="43.82589" lng="-79.10040" html="Some stuff to display in
the<br>Third Info Window" label="Marker Three" />
 </markers>
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JavedPune
Sent: Friday, January 18, 2008 7:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Issue with Google Maps Mashup with Mapguide
Hey
I am using google maps mash up code provided by Andy Morsell. I am doing
almost every thing as mentioned in the code the only thing I have changed is
the Feature resource. When I try to request.responseXML; it gives blank XML.
I am checking that with alert(xmlDoc.xml);.
Can some one please help me in this. Code snippet is provided as well
Regards
Javed
Code Snippet
request.open('GET', 'MuniMarkers.php', true); request.onreadystatechange =
function() { if (request.readyState == 4) { var xmlDoc =
View this message in context:
http://www.nabble.com/Issue-with-Google-Maps-Mashup-with-Mapguide-tp14950884
s16610p14950884.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
