[mapguide-users] Error to log on to MGOS 2.0.1 using MapGuide Maestro
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 14 04:12:37 EDT 2008
That is the expected behavior then.
You are using the bundled Apache server, which runs on port 8008.
Since http uses port 80, it is not possible to omit the port number.
You can re-configure apache to use port 80 if you like.
Regards, Kenneth Skovhede, GEOGRAF A/S
Intengu Technologies skrev:
> When I enter the url with the port number it works
> "http://localhost:8008/mapguide/mapagent/mapagent.fcgi"
> <http://localhost/mapguide/mapagent/mapagent.fcgi>
> Is there a way to resolve this
> 2008/7/14 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>:
>     What Zac meant was: What happens if you enter the url
>     "http://localhost/mapguide/mapagent/mapagent.fcgi"
>     <http://localhost/mapguide/mapagent/mapagent.fcgi> into the
>     address field in
>     your webbrowser?
>>     It works fine in a browser and does not work when I use MapGuide
>>     Maestro r3235.msi
>>     2008/7/14 Zac Spitzer <zac.spitzer at gmail.com
>>     <mailto:zac.spitzer at gmail.com>>:
>>         what happens if you open the url in a browser?
>>         z
>>         On Mon, Jul 14, 2008 at 5:01 PM, Intengu Technologies
>>         <sindile.bidla at gmail.com <mailto:sindile.bidla at gmail.com>> wrote:
>>         > That is the url I am using:
>>         > and the getting the error message.
>>         > 2008/7/13 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
>>         >> Have you tried using the full URL?
>>         >> It should work with the shorter form, though.
>>         >> I am getting the following error message: Failed to log on
>>         because: Failed
>>         >> to connect, please check network connection and login
>>         information. Extended
>>         >> error info: Failed to connect, perhaps session is expired?
>>         Extended error
>>         >> info: The remote server returned an error: (404) Not Found
>>         >> I am using MapGuide Maestro r3235.msi on MGOS 2.0.1 and
>>         MGOS Web Studio
>>         >> works fine.
>>         >> Sindile Bidla
>>         >> ________________________________
>>         >> _______________________________________________
>>         >> mapguide-users mailing list
>>         >> mapguide-users at lists.osgeo.org
>>         <mailto:mapguide-users at lists.osgeo.org>
>>         >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>         > Sindile Bidla
>>         Zac Spitzer -
>>         http://zacster.blogspot.com (My Blog)
>>         +61 405 847 168
>>     Sindile Bidla
>>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/87f40a2a/attachment.html
