[mapguide-users] Error to log on to MGOS 2.0.1 using MapGuide Maestro
Intengu Technologies sindile.bidla at gmail.com
Mon Jul 14 04:15:58 EDT 2008
Thank you now I understand.
2008/7/14 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>  That is the expected behavior then.
> You are using the bundled Apache server, which runs on port 8008.
> Since http uses port 80, it is not possible to omit the port number.
> You can re-configure apache to use port 80 if you like.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Intengu Technologies skrev:
> When I enter the url with the port number it works
> "http://localhost:8008/mapguide/mapagent/mapagent.fcgi"<http://localhost/mapguide/mapagent/mapagent.fcgi>
> Is there a way to resolve this
>> What Zac meant was: What happens if you enter the url
>> "http://localhost/mapguide/mapagent/mapagent.fcgi"<http://localhost/mapguide/mapagent/mapagent.fcgi>into the address field in
>> your webbrowser?
>> It works fine in a browser and does not work when I use MapGuide Maestro
>> r3235.msi
>> 2008/7/14 Zac Spitzer <zac.spitzer at gmail.com>:
>>> what happens if you open the url in a browser?
>>> z
>>> On Mon, Jul 14, 2008 at 5:01 PM, Intengu Technologies
>>> <sindile.bidla at gmail.com> wrote:
>>> > That is the url I am using:
>>> > and the getting the error message.
>>> > 2008/7/13 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>>> >> Have you tried using the full URL?
>>> >> It should work with the shorter form, though.
>>> >> I am getting the following error message: Failed to log on because:
>>> Failed
>>> >> to connect, please check network connection and login information.
>>> Extended
>>> >> error info: Failed to connect, perhaps session is expired? Extended
>>> error
>>> >> info: The remote server returned an error: (404) Not Found
>>> >> I am using MapGuide Maestro r3235.msi on MGOS 2.0.1 and MGOS Web
>>> Studio
>>> >> works fine.
>>> >> Sindile Bidla
>>> >> ________________________________
>>> >> _______________________________________________
>>> >> mapguide-users mailing list
>>> >> mapguide-users at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> > Sindile Bidla
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>> Sindile Bidla
>> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> Sindile Bidla
Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/2673449f/attachment.html
