Re[mapguide-users] dlining error
Marius_360 marius at openspatial.co.za
Fri Jul 18 08:15:42 EDT 2008
Ok, I changed it to:
var featureService = new MgFeatureService();
siteConnection.CreateService(MgServiceType.FeatureService);
featureService.CreateFeatureSource(resourceIdentifier, sdfParams)
But now I get:
OSGeo.MapGuide.MgUnclassifiedException: An unclassified exception occurred.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Ok, then you still have to do:
> Dim featureService as MgFeatureService =
> In VB.Net, because you cannot call the Mg* classes from JavaScript.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Marius_360 skrev:
>> Sorry, I’m using ASP.Net with JavaScript
>>> What do you mean?
>>> There is no MgServiceType declared in JavaScript?
>>> You wrote that you used VB.Net in the original post.
>>> You cannot use any of the Mg* classes from JavaScript because they are
>>> server side components.
>>> Marius_360 skrev:
>>>> I am using JavaScript :
>>>> featureService.CreateFeatureSource(resourceIdentifier, sdfParams);
>>>>> How do you construct the featureService variable?
>>>>> You should do something like:
>>>>> connection.CreateService(MgServiceType.FeatureService)
>>>>> featureService.CreateFeatureSource(...., ....)
>>>>> Marius_360 skrev:
>>>>>> Hi
>>>>>> I need to develop a redlining application for a client using VB.Net
>>>>>> and
>>>>>> JavaScript.
>>>>>> I converted the demo code available, but get stuck with the
>>>>>> “featureService.CreateFeatureSource” command, it gives me a “Objects
>>>>>> of
>>>>>> type
>>>>>> 'OSGeo.MapGuide.MgService' do not have such a member” error
>>>>>> Marius
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Redlining-error-tp18524267p18527944.html
