[mapguide-users] Inserting data in PostGis
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 31 10:49:40 EDT 2008
This might be the problem -
FeatureService.UpdateFeatures doesn't log errors correctly
the busy error is most likely because you haven't closed your featurereader
On Fri, Aug 1, 2008 at 12:37 AM, isca <mapguide2007 at gmail.com> wrote:
> Hello,
> I have some code in MapGuide for adding polygons/lines to SDF files. Now I
> am trying to get the same code working for PostGIS but until now without any
> result (displaying data is no problem). The first time I try to add
> something nothing happens and no error is generated. When I try to add
> something a second time I get the error "resource is busy".
> I am using the PostGIS provider together with MGOS 2.0.1.
> Is there anyone who has already implemented editing capibilities with
> PostGIS successfully ?
> View this message in context: http://www.nabble.com/Inserting-data-in-PostGis-tp18756037p18756037.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
