[mapguide-users] no MapGuideJavaApi in java.library.path
Rock Beans rockbeans at gmail.com
Thu Jun 12 13:47:45 EDT 2008
Why make your life complicated? It's "Summertime" enjoy. By the time you get
it working 85% stable on Linux a new version will be out and you will be
recompiling again. I have had luck on CentOS 4 and 5. Make sure you
JAVA_HOME and other Java variables are set. That set environment script is
annoying but very important to the compilation process. I wish they would
drop Java and make PHP modules to make life easier on both platforms. No one
really wants to run Tomcat if they don't have to.
Good luck,
The Rock
On Thu, Jun 12, 2008 at 2:34 AM, gimbrogno @smartlab <magnitudo9 at email.it>
wrote:
> Hi, I have installed Mapguide OpenSource on same linux systems (ubuntu 7.10
> and CentOS 5.1), but I have an error when try the java sample !!!
> When LinuxApt is compiled, it is not able to create the MapGuideApi.jar, so
> I have copied this jar from a windows in /WEB-INF/lib.
> Unber the directory tomcat/conf there is not Catalina/localhost, so I have
> created this two directories and I've copied the LinuxApt/mapguide.xml
> into.
> After these works the result page is "no MapGuideJavaApi in
> java.library.path... ", but MapGuideJavaApi is not a jar file but a static
> object (MapGuideJavaApi.so.0.7). Where is the library path where this
> object
> must be copied to?
> Under windows systems, I have no problems!!! There is anyone that uses
> MaGuide OpenSource under Linux that can helps me?
> Thanks in advantage... (I'm sorry for my english, but english is not my
> native language)
> http://www.nabble.com/no-MapGuideJavaApi-in-java.library.path-tp17794185p17794185.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/7ccb7d5e/attachment.html
