[mapguide-users] map refresh timeout
J Manafi jonathan.manafi at cctechnol.com
Tue Mar 4 15:40:11 EST 2008
We tried changing our renderer to GD because it wasn't causing the lock-ups
that AGG is producing, and I thought that had solved our problems. With the
release of MGOS 2.0, I wanted to test our maps to verify everything was
working before we upgraded on our production machines, and I noticed that
with the GD viewer, there is a large memory leak when zoomed in close and
when the same problematic layer is visible. However, I went back and tested
the map that I had included in Trac, and the problem does not show up. Also,
I did note, though, that when I zoom in to an area that is located outside
the bounds of a polygon like the one in the Trac example, the memory leak
doesn't occur; it only occurs when zooming in inside of similar polygons.
J Manafi wrote:
> I have experienced extremely long refresh rates when the zoom scale is
> really low (~1:33 or so). The time it takes to refresh for the Sheboygan
> example is at least 10x normal, and on a custom map, MapGuide server
> pretty much hangs at ~1:250 (currently sitting and waiting). Has anyone
> else noticed this behavior at low scales?
View this message in context: http://www.nabble.com/map-refresh-timeout-tp15442680s16610p15836576.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080304/88573c1a/attachment.html
