Re[mapguide-users] gistering new fusion templates
Jackie Ng jackie.ng at aecsystems.com.au
Thu Mar 6 02:55:01 EST 2008
Hi All,
I remember from the early betas of MGOS 2.0.0 that all I needed to do was
copy/rename one of the existing template folders, copy/rename the
corresponding xml file, change the path references in that xml file, and it
would then get picked up as a new template when invoking
EnumerateApplicationTemplates via the mapagent interface.
That doesn't seem to work in the final release. So how do you "register" a
new fusion template?
- Jackie
View this message in context: http://www.nabble.com/Registering-new-fusion-templates-tp15868197s16610p15868197.html
