Re[mapguide-users] gistering new fusion templates
Paul Spencer pagameba at gmail.com
Thu Mar 6 07:24:29 EST 2008
Hi Jackie,
I just tried this and it worked.  I copied the slate template folder
and called it slate2, then copied the slate.xml file and renamed it
slate2.xml and a second copy of slate appeared in studio.
Cheers
Paul
On 6-Mar-08, at 2:55 AM, Jackie Ng wrote:
> Hi All,
> I remember from the early betas of MGOS 2.0.0 that all I needed to
> do was
> copy/rename one of the existing template folders, copy/rename the
> corresponding xml file, change the path references in that xml file,
> and it
> would then get picked up as a new template when invoking
> EnumerateApplicationTemplates via the mapagent interface.
> That doesn't seem to work in the final release. So how do you
> "register" a
> new fusion template?
> - Jackie
> View this message in context: http://www.nabble.com/Registering-new-fusion-templates-tp15868197s16610p15868197.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Paul Spencer
CTO, DM Solutions Group Inc
http://www.dmsolutions.ca/
