[mapguide-users] MGOS2.0.2 bundled installation won'tsupportphpon IIS6
Andy Morsell amorsell at spatialgis.com
Wed Oct 1 12:00:30 EDT 2008
I run Apache and IIS side-by-side on my development Windows machines.  IIS
is by default bound to port 80 and Apache to port 8008.  If you want to
change Apache so that is bound to port 80 instead,  you can edit Apache's
httpd.conf configuration file and change the Listen directive.  If you do
this, you can use http://localhost and not have to specify
http://localhost:80
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
ed57gmc-bus at yahoo.com
Sent: Wednesday, October 01, 2008 8:53 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS2.0.2 bundled installation
Thanks Kenneth,
I didn't realise you could install Apache and IIS. What would be the reason
for doing so? I guess, then, that when the install guide was written, it was
with Apache in mind (i.e. specifying 8008)? I found other discrepancies and
things that need updating in the install guide. I was thinking of making
some corrections and submitting it.
Ed Jobe
----- Original Message ----
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Wednesday, October 1, 2008 12:02:24 AM
If you install Apache, it will use port 8008, because you may have other
stuff (IIS?) using port 80.
Whenever you do something with the Site Admin, it communicates with the
MapGuide service over a port on the loopback interface.
This port is NOT 8008, and should not be either.
Whenever your application communicates with the MapGuide service, it uses
another port on the loopback interface.
(It may redirect to another machine, but usually it is the same machine, and
thus a loopback).
Regards, Kenneth Skovhede, GEOGRAF A/S
ed57gmc-bus at yahoo.com skrev:
Are the port numbers the same in the web config file and the server config
file?
Yes, there are 3 ports config'd and they were the same in both files. They
weren't 8008 though. I didn't get prompted to specify them during install
like I did with 2.0.1.
Speaking of ports, the doc's mention localhost:8008. If I use that, it can't
find login.php. If I just use localhost, it can. Could someone explain why?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/c055e10e/attachment.html
