[mapguide-users] Scale rendering and layers missing with tile cahe.
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 2 11:12:30 EDT 2008
a tiled map has a defined set of scales, studio forces them to be equal
layers must fall within each of those scales for something to be displayed
I'm not quite sure what your asking?
the url link didn't work BTW
On Fri, Oct 3, 2008 at 12:35 AM, MMicallef-MTO
<Michael.Micallef at ontario.ca> wrote:
> I am looking for some direction,  I am producing a map for selected features
> (a map for each and reiterating through) - I was able - prior to moving to a
> tile cache (base layers) - to produce the map with the following built url:
> **attached in file
> -although it would only show the layers that were turned on in the map
> definition
> now I think I am getting the tile cache at the smallest scale when rendering
> the map - blank due to the scale display setting of the layer
> Is there anyway to render the map for a specific scale so that the layers
> defined to display at that scale are included - with the nuances of using
> base layers (tile caching)?
> Mike
> http://www.nabble.com/file/p19780541/nable%2Bpst1.txt nable+pst1.txt
> View this message in context: http://www.nabble.com/Scale-rendering-and-layers-missing-with-tile-cahe.-tp19780541p19780541.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
