[mapguide-users] How to config the WMS Data/Layer published byMapGuide and how to set the access way to it?
shreepad Ranadive shreepadr at valuecad.com
Mon Oct 6 13:18:47 EDT 2008
please check the co-ordinate system if you have wgs84 then and if you have
correct bounds you can see image see the sample data. but if you have the
data in state plane it does not do any co-ordinate transformation ( that
what i think) .. i have the same problem if i use state plane to create wms
image comes empty.
shreepad
JasonBirch wrote:
> I don't think that there are a lot of folks here with direct OpenLayers
> experience, so you may need to provide more details.
> I think that your first problem is probably due to JavaScript's
> same-origin policy.  Is your OpenLayers map running on a different host
> than the MapGuide server?
> For the second issue, I would probably want to run a network sniffer
> like Fiddler2 or the one built into FireBug to see what is being
> requested from the MapGuide WMS and if there is an exception being
> returned.  Also, make sure there is data in view at the scale being
> displayed.
> Jason
> -----Original Message-----
> From: carls
> Subject: [mapguide-users] How to config the WMS Data/Layer published
> I need to access Mapguide OverLayer to Openlayers, but there are
> something
> wrong with it (access denied with XMLHttpRequest.open(......)).
> So I moved to Add WMS Layer published by MapGuide. I tested many times,
> there is always a empty image displayed.
> How to config the WMS Data/Layer published by MapGuide and how to set
> the
> access way to it?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Shreepad Ranadive
Direcotor , Application Development
ValueCAD
444 Natoma St
Sanfrancisco,CA 94103
View this message in context: http://www.nabble.com/How-to-config-the-WMS-Data-Layer-published-by-MapGuide-and-how-to-set-the-access-way-to-it--tp19824876p19842299.html
