[mapguide-users] Oracle view crashing map server
Dragan Podvezanec dragan.podvezanec at gmail.com
Mon Oct 13 06:17:38 EDT 2008
Hi all.
I followed instructions how to make layer from oracle view on Haris's site,
and everything seemed ok, i managed to create few layers this way. But now I
have one view which crashes the server everytime I turn the layer on, with
following error:
(3216) An unclassified exception occurred.
Exception occurred in method
MgApplicationRepositoryManager.EnumerateParentMapDe
finitions at line 699 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\bu
ild_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
View has primary key, and table from which is created has spatial index, PK
and all metadata set.
Interrestingly, this layer shows ok using Autodesk Map3D and King.Oracle and
I can even edit it. also, the table from which is created this view shows ok
and doesn't throw any errors. But I need the view to show just last 5
records from the table. And this crashes mgserver. Any ideas?
View this message in context: http://www.nabble.com/Oracle-view-crashing-map-server-tp19952132p19952132.html
