[mapguide-users] Maestro: can't find the table containing the geometry field with SQLServerSpatial
Carl carlshe at 163.com
Tue Oct 14 12:28:40 EDT 2008
I don't know whether it is the issue of Maestro, or MGOS server, or even the
FDO provider for SQL server 2008.
I have a SQL server 2008 Database with more than 200 tables. some tables has
the name with the max length of 64 alpha-beta letters. there is only one
table, with name length of 35 letters, has a field of type 'geometry'. I
want to show the distribution map of this geometry with MapGuide OS.
I now created a feature datasource successfully with Maestro, by setting the
server, database, username,password, and then I tried to create a layer
referencing the featuredatasource. But Maestro always show a message as
follows:
  Failed to read schema from data source. The operation gave the error
message: Failed to find appropriate type for: xs:hexBinary.
  I traced the project 'Maestro' with VS 2008. and from 'public override
FeatureSourceDescription DescribeFeatureSource(string resourceID, string
schema)' of file 'HttpServerConnection.cs' to public
FeatureSourceDescription(System.IO.Stream stream)' of file
'FeatureSourceDescription.cs', and find the XML document, loaded from the
input stream, only covers the definition about 16 tables, and the spatial
table isn't among these tables.
I also test the SQL Server Spatial with only one table with a geometry
field, the feature datasource and the relative layer can be defined and can
be previewed.
Hope somebody could help me.
Thanks!
View this message in context: http://www.nabble.com/Maestro%3A-can%27t-find-the-table-containing-the-geometry-field-with-SQLServerSpatial-tp19977173p19977173.html
