[mapguide-users] Maestro: can't find the table containing thegeometry field with SQLServerSpatial
Jason Birch Jason.Birch at nanaimo.ca
Tue Oct 14 12:38:53 EDT 2008
Great problem report!
Sounds like it might be a missing type map in Maestro.
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Fe
atureSetReader.cs#L158
I would suggest adding a Trac Ticket (make sure to set the Component to
Maestro) so that Kenneth can address this.
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Jason
-----Original Message-----
Subject: [mapguide-users] Maestro: can't find the table containing
[snip]
I now created a feature datasource successfully with Maestro, by setting
the
server, database, username,password, and then I tried to create a layer
referencing the featuredatasource. But Maestro always show a message as
follows:  Failed to read schema from data source. The operation gave the
error
message: Failed to find appropriate type for: xs:hexBinary.
[snip]
