[mapguide-users] Generate map tiles from Oracle data
gingerbbm stuart.jones at jacobs.com
Thu Oct 16 05:13:48 EDT 2008
This is really excellent information.
So as I understand it if I convert my Oracle tables to SDF, and use the SDFs
as layers in a Base Layer group, then seed the tile cache using Zac's tool,
it'll fly.
My next question is whether MapGuide will use the same set of tiles for base
layers that are referenced in several different map definitions. I assume it
will... can somebody confirm this?
Thanks
Stuart
View this message in context: http://n2.nabble.com/Generate-map-tiles-from-Oracle-data-tp1336571p1340364.html
