[mapguide-users] Make changes to Map.MapDefinition.xml and add it to the session
Galois amihalas at yahoo.gr
Wed Oct 22 10:11:42 EDT 2008
Hello,
I was wondering if it is possible to change the runtime map via the
Map.MapDefinition.xml file.
Let's suppose that my map has the following xml file :
<?xml version="1.0" encoding="UTF-8" ?>
- <MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
  <Name>New Map</Name>
<CoordinateSystem>GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]</CoordinateSystem>
<Extents>
  <MinX>8.4399882654120386</MinX>
  <MaxX>13.284215393652543</MaxX>
  <MinY>46.980067237965471</MinY>
  <MaxY>44.094144693481766</MaxY>
  </Extents>
  <BackgroundColor>ffffffff</BackgroundColor>
  <Metadata><MapDescription>Italy Map</MapDescription></Metadata>
<MapLayer>
  <Name>cities</Name>
  <ResourceId>Library://GoSpatial/Layers/cities.LayerDefinition</ResourceId>
  <Selectable>true</Selectable>
  <ShowInLegend>true</ShowInLegend>
  <LegendLabel>cities</LegendLabel>
  <ExpandInLegend>true</ExpandInLegend>
  <Visible>true</Visible>
  <Group />
</MapLayer>
<MapLayerGroup>
  <Name>MainGroup</Name>
  <LegendLabel>Main Group</LegendLabel>
  <Group />
</MapLayerGroup>
Via Visual Studio I create a new MapLayer element with all the appropriate
information and save the file.
So my new Map.MapDefinition is the previous xml with the following layer
added:
<MapLayer>
  <Name>mountains</Name>
<ResourceId>Library://GoSpatial/Layers/mountains.LayerDefinition</ResourceId>
  <LegendLabel>LegendLabel</LegendLabel>
  <Group />
</MapLayer>
So, how can I use this new .xml in order to update my map definition, and
ofcourse to see the changes in the runtime map?
Thank you in advance!
View this message in context: http://www.nabble.com/Make-changes-to-Map.MapDefinition.xml-and-add-it-to-the-session-tp20111547p20111547.html
