[mapguide-users] selectAggregate error
Rodolfo Moreno rmoreno at voxiva.com
Mon Oct 27 18:20:04 EDT 2008
Hi Moog I got the same error in .NET.
I did what Mauricio suggested (put the selectDistinct statement before that
Addfeatureproperty ), but the same error is raised.
Could share you share your solution, please.
thanks in advance
Moog wrote:
> that's right. i fixed it making my own algorithm, but it want to know why
> i
> got that error. thanks
> Mauricio Villablanca wrote:
>> Your variable $aggregateOptions is a MgFeatureAggregateOptions object and
>> your featureService variable is a MgFeatureService object, right?
>> Moog wrote:
>>> hello,
>>> i need some help. Do you know why i get the following error in this
>>> line?
>>> $dataReader = $featureService->SelectAggregate($resId,
>>> $layer->GetFeatureClassName(), $aggregateOptions);
>>> where, $aggregateOptions is
>>> $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
>>> $aggregateOptions->SelectDistinct(true);
>>> Index is out of range. Exception occurred in method GetItem at line 81
>>> in
>>> file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\foundation\System/DisposableCollection.cpp
>>> - MgFeatureServiceHandler.ProcessOperation line 83 file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>>> - MgOpSelectFeaturesSpatial.Execute line 110 file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>>> - MgServerSelectFeatures.SelectFeatures line 249 file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
>>> - GetItem line 81 file
>>> thanks ;)
>>> View this message in context:
>>> http://www.nabble.com/selectAggregate-error-tp19690193p19690193.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/selectAggregate-error-tp1121116p1299635.html
> http://www.nabble.com/selectAggregate-error-tp19690193p19838822.html
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/selectAggregate-error-tp1121116p1384640.html
