[mapguide-users] MS SQL and SDF Join Problem
anakando anakando at yahoo.com
Sat Sep 13 01:51:10 EDT 2008
I guess there is not much i can do except exporting my sdf file to external
data and yes, this is the thing that most of the clients does not like.
Rock Beans wrote:
> I have seen this issue with the SQL Spatial FDO provider as well. The
> join options don't work everything is always one-to-one which means
> only objects with data in the joined table show up on map, not good. I
> also have seen this on Oracle, this seems to be an ongoing FDO issue
> within MapGuide. Sorry I have no solutions or work around other than
> exporting your sdf/shp/etc with all the external data which means you
> don;t need the join anymore. This is not dynamic though, I realize
> this but ti works. It brings more data batch processing to the table
> which most clients do not like.
> The Rock
> On Thu, Sep 11, 2008 at 10:18 PM, anakando <anakando at yahoo.com> wrote:
>> Hi guys..
>> I faced a very big problem (i guess) since i cannot overcome this problem
>> for almost 2 weeks! Let me simplify my problem. I have successful makes a
>> join between my sdf file and MS SQL, but the problem is,after joining,it
>> only show only first row data form MS SQL. The type of join is inner
>> join,
>> and relationship with secondary records is one-to-one. But when i change
>> type of join to left outer join, it will show all the data from MS SQL
>> but
>> with a 'null' value! I have do some research about this problem but i
>> can't
>> find something useful for me. If somebody out there already experienced
>> and
>> successful solved the problem, please let me know. TQ
>> View this message in context:
>> http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19448719.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19467729.html
