[mapguide-users] new Jx.PanelManager
Rock Beans rockbeans at gmail.com
Thu Sep 18 17:12:43 EDT 2008
The ultimate goal is to make MapGuide 2009 Enterprise work with Fusion
and Firefox 3. The end result of this is pretty much banging my head,
burning out... again and switching back to the basic viewer until
Fusion works it's issues out. Thanks for the links and very prompt
response!
On Thu, Sep 18, 2008 at 4:08 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> If you are following Fusion trunk, you'll have to do a lot of work to
> get your MapGuide templates working; Paul has committed a new version of
> Jx that is considerably different, and as part of this modified the
> widget architecture.  See messages below...
> Widget Architecture:
> http://trac.osgeo.org/fusion/ticket/117
> Jx API Changes:
> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000136.html
> Other 2.0/trunk changes:
> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000132.html
> If you're following the 1.1 branch of Fusion I think you should be OK,
> but will need to apply some changes here:
> http://trac.osgeo.org/mapguide/ticket/676
> I'd suggesting asking questions about Jx on the Fusion mailing lists.
> http://trac.osgeo.org/fusion/wiki/MailingLists
> Jason
> -----Original Message-----
> From: Rock Beans
> Subject: [mapguide-users] new Jx.PanelManager
> Has new Jx.PanelManager been removed from the new SVN of Fusion. My
> older MapGuide templates are not working.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
