[mapguide-users] creating georeferenced world file[jgw file]
aktaylor akt at frikshun.com
Tue Apr 14 11:31:00 EDT 2009
Did you get an answer to this?
Can you send me a code snippet for the generation of your JPG file from the current map view as well as how the world file was generated?
Dear Sir/Madam
I am new to programming open source mapguide[One Month].I have started to like it and catching it really fast.But presently i have stuck with a problem which i think can be solved with your kind support.
The scenario is this that i want to generate the georeferenced image of the current view of the map.I have successfully generated the jpg file of the current map view now I want to generate a .jgw file also of the generated image. I know that to generate to world file[.jgw file] i need to know information of the below mentioned six line:
Line 1: A, pixel size in the x-direction in map units/pixel
Line 2: D: rotation about y-axis
Line 3: B: rotation about x-axis
Line 4: E: pixel size in the y-direction in map units, almost always negative
Line 5: C: x-coordinate of the center of the upper left pixel
Line 6: F: y-coordinate of the center of the upper left pixel
I can generate all the values except Line 1 and Line 4. It would be very helpful if you could help me out with this. Also if you can provide me with a small working example code.[I am doing allmy development . net].
Waiting for your quick reply and help.
Thanks & Regards
Sanjay Pandey
View this message in context: http://n2.nabble.com/creating-georeferenced-world-file-jgw-file--tp1818688p2633771.html
