[mapguide-users] Mapguide site works fine on host machine, not running properly on others
Jonathan W jwitcoski at tycotelecom.com
Tue Apr 14 12:38:24 EDT 2009
All problems solved!!!
Thank you Dave!!
I changed my Settings in Site Admin and now the WMS server works.
I also found that I needed to change from localhost to my server name in the KMLCONTENTFACTORY.PHP file.
Now to modify the sample code for use with my own data...
Did you check your settings in Site Admin for WMS and change the server name from localhost?
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan W
Sent: Tuesday, April 14, 2009 7:26 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide site works fine on host machine, not running properly on others
I have just started to use mapguide, Great program!!
I have downloaded the google earth sample and loaded it to my machine (localhost)
http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php
I had to change a line of code to make the thing work:  header('Content-type: application/vnd.google-earth.kml+xml'); thanks to a previous post
http://n2.nabble.com/Google-Earth-and-MapGuide-Example-td1817668.html#a1817668
I have also changed the server name in various parts of the code files
The sample works perfectly on my machine but when I try to run it from another machine within our secure network the KMLContentFactory.php does not generate a KML file. (the rest of mapguide works fine thou)
I have also turned a few layers on for a WMS server.  It works great on my computer but when I try another machine it tells me that a WMS server is there but it refuses to actually display anything.
Has anyone encountered this problem before? I have set my permissions for the mapguide folder to be readable and writeable to everyone.  I am using IIS on a Windows XP computer.  Any ideas? Is it something with the server I am running or with the code in mapguide?
View this message in context: http://n2.nabble.com/Mapguide-site-works-fine-on-host-machine%2C-not-running-properly-on-others-tp2633065p2633065.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Mapguide-site-works-fine-on-host-machine%2C-not-running-properly-on-others-tp2633065p2634064.html
