[mapguide-users] Display current mouse coordinates in MapGuide window?
Zac Spitzer zac.spitzer at gmail.com
Wed Aug 5 02:41:11 EDT 2009
the mapguide classic viewer is an activex control so no, tis been a while
since i looked at the activex version, but the 6.x releases did from memory,
your reg hack is for the ancient 5.0 version? (unless the newer
(older)one refernces the old
both the classic ajax and the fusion viewers already display the
co-ords out of the box?
z
On Wed, Aug 5, 2009 at 4:17 PM, CroNicoRn<ah_jid at yahoo.com> wrote:
> I found this tips and trick on wesite.. can it use on mapguide open source??
> You can switch on the dynamic mouse coordinates (in map units) by adding a
> key in Registry.
> Run RegEdit and into the branch
> HKEY_CURRENT_USER\Software\Autodesk\MapGuide Viewer\5.0\Viewer
> add a REG_DWORD type key:
> DisplayMousePosition
> with value of 1
> be careful when editing Registry
> http://www.myguidepages.com  http://n2.nabble.com/file/u115131/ajid.jpg
> View this message in context: http://n2.nabble.com/Display-current-mouse-coordinates-in-MapGuide-window--tp3389452p3389452.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
