[mapguide-users] Syntax Error when trying to view data
Nickthetemp nickthetemp at gmail.com
Thu Aug 6 14:41:11 EDT 2009
I was able to get this fixed.
In the ODBC Administrator there is an option to enable quoted identifiers,
which is unchecked by default. Checking this fixed the error.
Hope this will help someone else
Nick
Nickthetemp wrote:
> Hello everyone.
> I am having a problem with an ODBC connection with a sybase database.
> I am running mapguide 2010 on a windows 2003 server. I have set up the
> database connections using the ODBC connection manager.
> I have 2 DB2 databases and 2 sybase databases connected.
> The 2 DB2 are working fine.
> The problem is with the sybase connections.
> When I test the connection in MapGuide Studio, I am able to connect
> succesfully. I am able to view the tables, and set geometry for my
> Latitude and Longitude values.
> When I change to the preview, I can see the list of tables and view the
> table properties.
> My problem occcurs when I click the view Data button. I get the following
> error:
> An exception occurred in FDO component. RDBMS: [DataDirect][ODBC Sybase
> Wire Protocol driver][SQL Server]Incorrect syntax near 'MailingList'.
> This occurs on every table in the database. The 'MailingList' in the above
> error represents the last column in the table, and changes to the last
> column in whatever table I am trying to view.
> There are no simularities in the last columns so it is not a data issue. I
> was able to connect and view the data in the same databases when using
> mapguide enterprise 2009, on a linux server.
> This problem also means I can not view the data on my maps.
> Any help would be appreciated.
> Nick
View this message in context: http://n2.nabble.com/Syntax-Error-when-trying-to-view-data-tp3391240p3400081.html
