[mapguide-users] Regarding How to set the Initial Map View
ravinder.singh at BIRLASOFT.COM ravinder.singh at BIRLASOFT.COM
Tue Feb 17 05:49:11 EST 2009
Hi Kenneth,
Yes it solved out my problem.
Thanks
Regards,
Ravi
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Tuesday, February 17, 2009 1:38 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Regarding How to set the Initial Map View
There was a bug in Maestro that swapped some x/y coordinates, try using
the newest build (r3260).
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
Hi All,
How to set the Initial Map View (Lower Left and Upper Right (XY
Coordinates)) in MapGuide Maestro.
If I click on Set View to Current Layers Extent (In Maestro) & Run the
layout then map does not appears in the viewer , seems that  map is
there on the viewer but at different position which is not visible at
startup, Because when I try to pan the map multiple times left or right
up or down  it appears.
I am using MGOS 2.0, .Net
Please assist...
Thanks,
Ravi
"This message and any attachments are solely for the intended recipient
and may contain Birlasoft confidential or privileged information. If you
are not the intended recipient,any disclosure,copying, use, or
distribution of the information included in this message and any
attachments is
prohibited. If you have received this communication in error, please
notify us by reply e-mail at (administrator at birlasoft.com) and
permanently delete this message and any attachments. Thank you."
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is
prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090217/048fca54/attachment.html
