[mapguide-users] Regarding How to set the Initial Map View
ravinder.singh at BIRLASOFT.COM ravinder.singh at BIRLASOFT.COM
Wed Feb 18 04:12:32 EST 2009
Although it solved out my problem of setting the initial map View at
Design time in maestro.
Now I have written the code to set the layer of map dynamically by using
maestro api, the map is showing correct layer in viewer. Now I want to
set the Initial Map View (Lower Left and Upper Right (XY Coordinates))
at run time by fetching the extents of the layer.
Please assist...
Thanks
Ravinder
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Tuesday, February 17, 2009 4:19 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Regarding How to set the Initial Map View
Hi Kenneth,
Yes it solved out my problem.
Thanks
Regards,
Ravi
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Tuesday, February 17, 2009 1:38 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Regarding How to set the Initial Map View
There was a bug in Maestro that swapped some x/y coordinates, try using
the newest build (r3260).
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
Hi All,
How to set the Initial Map View (Lower Left and Upper Right (XY
Coordinates)) in MapGuide Maestro.
If I click on Set View to Current Layers Extent (In Maestro) & Run the
layout then map does not appears in the viewer , seems that  map is
there on the viewer but at different position which is not visible at
startup, Because when I try to pan the map multiple times left or right
up or down  it appears.
I am using MGOS 2.0, .Net
Please assist...
Thanks,
Ravi
"This message and any attachments are solely for the intended recipient
and may contain Birlasoft confidential or privileged information. If you
are not the intended recipient,any disclosure,copying, use, or
distribution of the information included in this message and any
attachments is
prohibited. If you have received this communication in error, please
notify us by reply e-mail at (administrator at birlasoft.com) and
permanently delete this message and any attachments. Thank you."
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
attachments is
"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is
prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090218/1f61619a/attachment.html
