[mapguide-users] Regarding How to set the Initial Map View
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 18 05:05:09 EST 2009
Please have a look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs#L1895
It shows how to read the extent of data, as well as how to set it.
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> Hi,
> Although it solved out my problem of setting the initial map View at
> Design time in maestro.
> Now I have written the code to set the layer of map dynamically by
> using maestro api, the map is showing correct layer in viewer. Now I
> want to set the Initial Map View (Lower Left and Upper Right (XY
> Coordinates)) at run time by fetching the extents of the layer.
> Please assist...
> *Thanks*
> Ravinder
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *ravinder.singh at BIRLASOFT.COM
> *Sent:* Tuesday, February 17, 2009 4:19 PM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* RE: [mapguide-users] Regarding How to set the Initial Map View
> Hi Kenneth,
> Yes it solved out my problem.
> Thanks
> Regards,
> Ravi
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Tuesday, February 17, 2009 1:38 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Regarding How to set the Initial Map View
> There was a bug in Maestro that swapped some x/y coordinates, try
> using the newest build (r3260).
> ravinder.singh at BIRLASOFT.COM <mailto:ravinder.singh at BIRLASOFT.COM> skrev:
> Hi All,
> How to set the Initial Map View (Lower Left and Upper Right (XY
> Coordinates)) in MapGuide Maestro.
> If I click on Set View to Current Layers Extent (In Maestro) & Run the
> layout then map does not appears in the viewer , seems that  map is
> there on the viewer but at different position which is not visible at
> startup, Because when I try to pan the map multiple times left or
> right up or down  it appears.
> I am using MGOS 2.0, .Net
> Please assist...
> *Thanks,*
> Ravi
> "This message and any attachments are solely for the intended
> recipient and may contain Birlasoft confidential or privileged
> information. If you are not the intended recipient,any
> disclosure,copying, use, or distribution of the information included
> in this message and any attachments is
> prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com
> <mailto:administrator at birlasoft.com>) and permanently delete this
> message and any attachments. Thank you."
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> notify us by reply e-mail at (administrator at birlasoft.com) and
> permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090218/de5cab8d/attachment.html
