[mapguide-users] Regarding How to set the Initial Map View
ravinder.singh at BIRLASOFT.COM ravinder.singh at BIRLASOFT.COM
Fri Feb 20 01:18:29 EST 2009
Hi Kenneth & All,
Now my problem is that I have to select/highlight the multiple features
on the run time map/layer depending upon the search condition of user.
Please help.........
Thanks & Regards,
Ravinder
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Wednesday, February 18, 2009 8:11 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Regarding How to set the Initial Map View
Thanks Kenneth earlier I was referring MaestroAPI dll from some other
location. Problem is solved now.
Regards,
Ravinder
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Wednesday, February 18, 2009 7:53 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Regarding How to set the Initial Map View
The "GetSpatialExtent" method is new, so you have to use the
MaestroAPI.dll from
thre preview binaries or grab them from the folder where you installede
Maestro.
The SpatialContext is likely to contain wrong information (eg, just
extent of the entire coordinate system).
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
Hi Kenneth,
I have gone thru the file you referred.
I have problem in Topology.Geometries.IEnvelope env =
ldef.GetSpatialExtent(); at line no 1912
GetSpatialExtent() method is not coming in in ldef object I created.
And then I tried to write just the following code
OSGeo.MapGuide.MaestroAPI.LayerDefinition ldef =
conn.GetLayerDefinition(mylayer.ResourceId);
//Topology.Geometries.IEnvelope env = ldef
OSGeo.MapGuide.MaestroAPI.FdoSpatialContextList lst =
conn.GetSpatialContextInfo(ldef.Item.ResourceId, false);
 mapDef.Extents.MinX =
System.Convert.ToDouble(lst.SpatialContext[0].Extent.LowerLeftCoordinate
.X);
 mapDef.Extents.MinY =
.Y);
 mapDef.Extents.MaxX =
System.Convert.ToDouble(lst.SpatialContext[0].Extent.UpperRightCoordinat
e.X);
 mapDef.Extents.MaxY =
e.Y);
Which gives me the incorrect coordinates, I verify it with maestro, it
is different from that one showing in maestro, in effect the viewer also
is not able to show the map.
Thanks
Ravinder
Sent: Wednesday, February 18, 2009 3:35 PM
Please have a look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/Resou
rceEditors/MapEditor.cs#L1895
It shows how to read the extent of data, as well as how to set it.
Although it solved out my problem of setting the initial map View at
Design time in maestro.
Now I have written the code to set the layer of map dynamically by using
maestro api, the map is showing correct layer in viewer. Now I want to
set the Initial Map View (Lower Left and Upper Right (XY Coordinates))
at run time by fetching the extents of the layer.
Please assist...
Thanks
Ravinder
Sent: Tuesday, February 17, 2009 4:19 PM
Hi Kenneth,
Yes it solved out my problem.
Thanks
Regards,
Ravi
Sent: Tuesday, February 17, 2009 1:38 PM
There was a bug in Maestro that swapped some x/y coordinates, try using
the newest build (r3260).
Hi All,
How to set the Initial Map View (Lower Left and Upper Right (XY
Coordinates)) in MapGuide Maestro.
If I click on Set View to Current Layers Extent (In Maestro) & Run the
layout then map does not appears in the viewer , seems that  map is
there on the viewer but at different position which is not visible at
startup, Because when I try to pan the map multiple times left or right
up or down  it appears.
I am using MGOS 2.0, .Net
Please assist...
Thanks,
Ravi
"This message and any attachments are solely for the intended recipient
and may contain Birlasoft confidential or privileged information. If you
are not the intended recipient,any disclosure,copying, use, or
distribution of the information included in this message and any
attachments is
prohibited. If you have received this communication in error, please
notify us by reply e-mail at (administrator at birlasoft.com) and
permanently delete this message and any attachments. Thank you."
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
attachments is
attachments is
attachments is
attachments is
"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is
prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090220/7be309d5/attachment.html
