[mapguide-users] Regarding How to set the Initial Map View
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Feb 20 03:33:59 EST 2009
Could you try to re-phrase your question, I don't understand what/if you
are asking.
Also, it's better to start a new thread for a new topic, the people who
are likely
to answer your question, may not look at a subject with this title.
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> Hi Kenneth & All,
> Now my problem is that I have to select/highlight the multiple
> features on the run time map/layer depending upon the search condition
> of user.
> Please help.........
> *Thanks & Regards,*
> Ravinder
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *ravinder.singh at BIRLASOFT.COM
> *Sent:* Wednesday, February 18, 2009 8:11 PM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* RE: [mapguide-users] Regarding How to set the Initial Map View
> Thanks Kenneth earlier I was referring MaestroAPI dll from some other
> location. Problem is solved now.
> *Regards,*
> Ravinder
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Wednesday, February 18, 2009 7:53 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Regarding How to set the Initial Map View
> The "GetSpatialExtent" method is new, so you have to use the
> MaestroAPI.dll from
> thre preview binaries or grab them from the folder where you
> installede Maestro.
> The SpatialContext is likely to contain wrong information (eg, just
> extent of the entire coordinate system).
> ravinder.singh at BIRLASOFT.COM <mailto:ravinder.singh at BIRLASOFT.COM> skrev:
> Hi Kenneth,
> I have gone thru the file you referred.
> I have problem in Topology.Geometries.IEnvelope env =
> ldef.GetSpatialExtent(); at line no 1912
> GetSpatialExtent() method is not coming in in ldef object I created.
> And then I tried to write just the following code
> OSGeo.MapGuide.MaestroAPI.LayerDefinition ldef =
> conn.GetLayerDefinition(mylayer.ResourceId);
> //Topology.Geometries.IEnvelope env = ldef
> OSGeo.MapGuide.MaestroAPI.FdoSpatialContextList lst =
> conn.GetSpatialContextInfo(ldef.Item.ResourceId, false);
>  mapDef.Extents.MinX =
> System.Convert.ToDouble(lst.SpatialContext[0].Extent.LowerLeftCoordinate.X);
>  mapDef.Extents.MinY =
> System.Convert.ToDouble(lst.SpatialContext[0].Extent.LowerLeftCoordinate.Y);
>  mapDef.Extents.MaxX =
> System.Convert.ToDouble(lst.SpatialContext[0].Extent.UpperRightCoordinate.X);
>  mapDef.Extents.MaxY =
> System.Convert.ToDouble(lst.SpatialContext[0].Extent.UpperRightCoordinate.Y);
> Which gives me the incorrect coordinates, I verify it with maestro, it
> is different from that one showing in maestro, in effect the viewer
> also is not able to show the map.
> *Thanks*
> Ravinder
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* Wednesday, February 18, 2009 3:35 PM
> Please have a look at the Maestro code:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs#L1895
> It shows how to read the extent of data, as well as how to set it.
> Hi,
> Although it solved out my problem of setting the initial map View at
> Design time in maestro.
> Now I have written the code to set the layer of map dynamically by
> using maestro api, the map is showing correct layer in viewer. Now I
> want to set the Initial Map View (Lower Left and Upper Right (XY
> Coordinates)) at run time by fetching the extents of the layer.
> Please assist...
> *Thanks*
> Ravinder
> *ravinder.singh at BIRLASOFT.COM <mailto:ravinder.singh at BIRLASOFT.COM>
> *Sent:* Tuesday, February 17, 2009 4:19 PM
> <mailto:mapguide-users at lists.osgeo.org>
> Hi Kenneth,
> Yes it solved out my problem.
> Thanks
> Regards,
> Ravi
> *Sent:* Tuesday, February 17, 2009 1:38 PM
> There was a bug in Maestro that swapped some x/y coordinates, try
> using the newest build (r3260).
> Hi All,
> How to set the Initial Map View (Lower Left and Upper Right (XY
> Coordinates)) in MapGuide Maestro.
> If I click on Set View to Current Layers Extent (In Maestro) & Run the
> layout then map does not appears in the viewer , seems that  map is
> there on the viewer but at different position which is not visible at
> startup, Because when I try to pan the map multiple times left or
> right up or down  it appears.
> I am using MGOS 2.0, .Net
> Please assist...
> *Thanks,*
> Ravi
> "This message and any attachments are solely for the intended
> recipient and may contain Birlasoft confidential or privileged
> information. If you are not the intended recipient,any
> disclosure,copying, use, or distribution of the information included
> in this message and any attachments is
> prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com
> <mailto:administrator at birlasoft.com>) and permanently delete this
> message and any attachments. Thank you."
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> notify us by reply e-mail at (administrator at birlasoft.com) and
> permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090220/3b7109b7/attachment.html
